メインコンテンツにスキップ
New Nitendo 3DS XLは2014年10月11日に発売されたNintendo 3DS LLの後継モデルとして、日本国内で発売されました。北米では、2015年2月に発売されました。
374回答 すべてを表示
My volume and 3D slider are unresponsive
I took my system apart, and upon reassembly, the volume and 3D sliders on both sides of the screen no longer respond or adjust the systems volume or 3D depth, respectively.
What should I replace, and could I possibly fix a scratched or damaged ribbon cable?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
First of all, you have to know how to open the top shell. The solution is shown here: How to remove top shell of New 3DS XL 2015?.
Now if both left and right speaker works(by any chance because of the first reason) , the ribbon cable should be completely fine, and you probably just didn't align the exterior slider and the interior one correctly. Now in this image
, inside the red circle is the small circuit board that connects to the speaker. You can see there's a little black thing sticking out. That is the "interior" slider, and in the yellow circle which is the "exterior" slider(not the perfect angle but meh you can see it), you can see there's a place for that little black thing to stay. This is how the interior slider move when you move the exterior one. To align them, you simply just have to move the exterior slider to very bottom and do the same to the little black piece, then place that small board back and make sure the little black piece is aligned perfectly. The same is to be done at the other side as well.
However if you tried that method and they are still not working, consider watching a video of replacing the top screen as the ribbon cables are going through the hinge the same way.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
cesar3 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 17
今までの合計 1,204
