メインコンテンツにスキップ
This laptop from HP was released in November 2011. It has a 17.3" display and and comes in either silver or nero black.
Webcam connector HP Envy 17
I opened my HP Envy 17 to remove the broken plastic bits from the broken left hinge & when I put it back together the webcam is not working. Can someone please tell me where the webcam connects to the board, I can't find it on the internet & I don't want to open it until I know what I missed. Thanks for any help, much appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
Here is a link to the service manual for your laptop.
http://h10032.www1.hp.com/ctg/Manual/c03...
On p.20 it says that the Display assembly includes the following: display panel cable, web camera/microphone module and cable, and 2 wireless antenna cables and transceivers
On p.71 it shows the removal of cables from the systemboard. The #1 cable in the image shows that there are two connectors, one for the display cable and the other for the display function cable.
I think that the webcam cable and microphone cable etc are part of the display function cable which also goes through the hinge to the motherboard.
Update (11/05/2016)
Hi @zandra6,
OK. Here is the link for your model HP Envy 17 (also known as HP ENVY 17-j111tx F7P64PA).
http://h10032.www1.hp.com/ctg/Manual/c04...
On p.64 Item #3 shows the webcam cable connection to the systemboard. The webcam/microphone cable also is shown on p.22 Item #6 and on p.66 Item #2.
Hopefully it is the right one this time.
ps Stupid thought but have you checked the webcam under Imaging Devices in Device Manager to see if it is enabled/disabled and that the drivers are OK?
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Sadly this manual does not match the inside of the laptop. It was bought in 2014 & has a completely different layout. I did however check all the cables that came through the hinges & they are all connected but webcam still not working. Is there another manual out there for the newer model. I still can't find it. Thanks for your help, much appreciated.
さんによる
Hi, What is your exact model number?
さんによる
Hi. It's F7P64PA. Thanks jayeff
さんによる
コメントを追加
回答を追加する
Zandra Gibbs さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 585
