Why does the battery of my device dies very fast?
After a short period of usage, the battery of the device drains.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
1- Check the battery condition , keep in mind the Cruz T301 battery's life is about 6 hours on a full charge..
2- Go to menu> Settings > About Device > Battery, so that you can check your battery usage.
3- If the battery is in bad condition, you should replace it.
4- Also, you might have some audio and game apps that use a lot of battery power.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 84
1件のコメント
Does this happen at the same location or at different locations. Does it have any problems with your home network? Are you receiving a strong signal when its trying to connect or week one?
Jimfixer さんによる
