メインコンテンツにスキップ
1.83 GHz Core Duo or 1.83, 2,もしくは2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201回答 すべてを表示
2006 Intel iMac wouldn't power on
My 2006 iMac was dead since I had long trip back. I unplugged the machine before I left. Now nothing happened when the machine plugged and press the button (no sound just black screen). It worked fine before I left.
I tried to take apart the machine and all look fine inside. I replaced the logic board battery and still same. But I found once I put on the plug, it has "da da da" sound continually from behind the logic board. It means any part broken?
Thanks for help to save my old Mac.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Three beeps is a RAM issue. Reseat the RAM and tell us what it does.
iMac Intel 17" RAM Replacement
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Just throwing my two cents in here. Almost every time I see one of these machines in a store its because of a failed/failing power supply. After you've tried what Mayer has suggested, I agree with Vincent that it is indeed a power supply issue.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Hi Michael !
I would 1st suggest you to try unplugging the machine, holding the power button for 10s then plugging it back it.
I had the same problem with the same mac model. I ended up replacing the power supply unit (iFixit sells that part) and it now works well. Couldn't tell if your computer has the same problem but I'm glad that it fixed mine.
Hope this helps !
iMac G5/Intel Power Supplyの画像
製品
$49.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Michael Chou さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 124
