front and back lights will not turn off
How do I get the front and back lights to turn off on my 2009 chevy equinox ls. I have tried everything that I know to do, but I still have the problem.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Laveal, Check the head light relay and switch out with a known good one that matches, relay is in interior fuse panel. If lights still not functioning properly, probable faulty head light/multifunction switch or BCM. If you do not feel comfortable checking or replacing parts have a good technician check, diagnose and estimate repair. Link below will give you an idea of what is involved in changing multi function switch. Good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 857
