メインコンテンツにスキップ
Wii Uはハンドヘルドデバイスとペアになったゲームコンソールです。ユーザーは、GamePadでゲームをすることもできます。コンソールの修理は簡単で、デバイスはほとんどがモジュラーです。
191回答 すべてを表示
Repairing/replacing console AC adapter port
The AC adapter port on the console feels loose. Whenever I plug the power adapter I need to move it in different positions in order to power up the console. I was wondering if it's possible to just solder it correctly or replace it?
I found the part here but would it be just a matter of soldering it in place?
Thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
crazy ive been having the same problem thx for the anwsers on this guys post ill keep yall updated
さんによる
コメントを追加
2件の回答
ベストアンサー
I would first try to solder it on again, should usually work.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
So, I made something stupid: I was trying to solder the part. I made several attempts and I couldn't get it to work. Now, before I was able to play sometimes by adjusting and moving the power cord in different ways. So me being stupid I plugged the power cord and attempted to solder the part while it was connected to find the sweet spot and put the part in place... and I got a spark and now I can't make it work, doesn't matter how much I move the cable. How can I test if I damaged it?
さんによる
Well, at least I know I didn't kill it. It still works but even after soldering in place it's still hard to make it work. Thanks.
さんによる
コメントを追加
Definitely try re-soldering it back in place first. Sometimes it can get loose and all it needs is some fresh solder to keep it in place.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ruben Tenorio さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 21
今までの合計 1,844
