My heater will not turn on.
I plug in the heater to a wall outlet but nothing happens. The display doesn't light up and the buttons won't work either.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Make sure your heater is positioned in the upright position, and then check the powercord for any bent prongs or frayed spots. If you find any of these, you might have to replace the cord. For more information, refer to [ Holmes HEH8031 Troubleshooting|Heater Troubleshooting Page]
このアンサーは役に立ちましたか?
I would check out the inside and look for burnt fuses, switches, etc. space heaters are cheap the parts inside them are cheap.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 30
今までの合計 19,956
