メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Can I replace keyboard from A1260?
Can I replace keyboard from A1260 to A1150 or something newer (touchpad & keyboard - top cover)?
I know that battery will work for A1260 and for A1150
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
If you are looking for all of the pieces that make up the upper case here is what you'll need:
The upper cases them selves are not quite the same so you really can't swap them around in case you have a junker.
Given the age of this system and the cost of buying the parts here you may want to think if its time to get a newer system (new or used). While I loved my old Santa Rosa (A1226) it was time to retire it two years ago. Many apps and OS just won't run on this baby and its hardware limitations likewise make it hard to justify using any longer.
Replace an upper case assembly compatible with the model A1150 MacBook Pro 15 inch laptop. Includes palmrest area, trackpad, trackpad cable, and power button.の画像
製品
MacBook Pro 15" (Model A1150) Upper Case
$49.99
Replace an upper case and trackpad compatible with the model A1226 MacBook Pro 15 inch laptop. Includes the palmrest area, trackpad, trackpad cable, and power button.の画像
製品
MacBook Pro 15" (Model A1226) Upper Case
$49.99
Replace your backlit keyboard.の画像
製品
MacBook Pro 15" (Model A1150, A1211, A1226) Keyboard
$99.99
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
So, i can make a nice deal to get notworking A1260, i need from that just keyboard and charging device. Yep! in my mac dented Upper case, but i can algin it. And main question:
Will work A1260 keyboard(and maybe trackpad) in A1150?
(that is all i want to know)
さんによる
"The upper cases them selves are not quite the same so you really can't swap them around in case you have a junker."
さんによる
Okay, keyboard from A1260(MB133RS/A) for A1150 will works. thanks for answers.
さんによる
コメントを追加
Since I do not have these exact two laptops in my possession I cannot say for sure. However, they look close enough that I would suspect a majority of the parts are the same. In short if it fits and plugs in it will work.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Ilia さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 20
今までの合計 336
