How to break security code?
i have an nokia 1110 and i didnt use it for many years and now forgot the security code .so now not to use it . i need to break the security code . help me ?
12345 ---> This is the default security code on all Nokia phones before a user changes it. Try this first when asked for the code.
If that doesn't work try the codes below, they may help you solve your problem but not guaranteed!
Insert the following codes from the phones dial pad:
*#7780# ---> (reset to factory settings)
*#2640# ---> (Displays phone security code in use) ??
*#7370# ---> (Deep Reset: Removes everything and puts the phone right back to factory settings)
*#7328748263373738# ---> (Resets security code)
I've not tested this one myself so i'm unsure if it will do anything!
このアンサーは役に立ちましたか?
x igat password
thanks brother
salaams every body i have a Nokia 106.1 i have tried all the codes available on the net and none work when i press *# it does not display and after putting all codes in it says code error I've been trying all sorts for the pass two weeks
Hi Abdullah valli, try this alternate way to hard reset your phone...
With the phone powered off, press and hold the Power button + Answer/End key for about 5 seconds until the red and green indicator lights start to alternate.
Sometimes pressing "*#code#" doesn't always work, If it doesn't work try inserting the code using this format... *#*#code#*#*
Sir nokia 1110 ka format code kiya hai
このアンサーは役に立ちましたか?
Sir nokia 1110 phone format code kiya hai
このアンサーは役に立ちましたか?
I have a nokia 6700 classic and it is asking for secruity code as it has been years i can not remember the code tryd all the obvious solutions but stil not working any help guys?
このアンサーは役に立ちましたか?
*#7328748263373738# resets security code.
Default security code is 12345
If you still can't reset the security code then the only way would be to flash the phone & restore the Nokia firmware. That process involves more time on your part as you'll need to download the nokia software & the firmware specific to your device. The links below are for the "How-To" tutorial to accomplish these tasks!
Link 1= Firmware downloads for Nokia 6700
Link 2= How-to tutorial & nokia software programs
過去 24時間: 0
過去 7 日: 3
過去 30 日: 5
今までの合計 31,931
