Why does my laptop keep turning off?
When using my laptop, sometimes it randomly turns off.
Hey Tim,
Mine used to turn off because of a faulty battery which seems common in these laptops.
SOLUTION: There is a setting in “advanced power options” > Battery > Critical Battery Action. Change the “Plugged in” setting to “Do Nothing”.
I hope this helps! Good luck!
このアンサーは役に立ちましたか?
There are several reasons why a laptop may randomly shut off during use. One of the most common is the computer is overweighting. I suggest reviewing the trouble shooting guide under computer is over heating for suggestions on how to resolve this issue.
このアンサーは役に立ちましたか?
Personally I have the same problem but this is not randomly. My computer turn off when i launch a big application like Adobe Premier or a game.
このアンサーは役に立ちましたか?
Check my post on the main thread. I hope it helps you!
過去 24時間: 0
過去 7 日: 5
過去 30 日: 23
今までの合計 5,915
2 件のコメント
iFixit Technical Writing Project
L Pfaff さんによる
I have the same problem the display turned off if not used with in 1 or 2 mins. I then have to sign on to some of my programs. I have adjusted the power settings but it does not help.
I have a ASUS zen book running windows 10
ed miller さんによる
