Why is my location suddenly inaccurate?
I recently went on a long trip using my gps, and now the location keeps showing up as about a block away from where I really am.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Multiple things can cause your GPS to malfunction completely or become inaccurate. Sometimes this can be caused by a software glitch. The simple solution to a software glitch is to reset your device by turning it off and then turn it back on again. If that does not correct the problem, try and get a clear, unobstructed view of the sky. If there are too many obstructions between you and the sky, it could cause the GPS to lose accurate signal. Obstructions would include; buildings, trees, mountains, caves, etc. If you have a clear line of sight to the sky and still have little or no GPS signal, your GPS unit within the device is most likely malfunctioning and needs replacing.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 3
過去 30 日: 23
今までの合計 283
