Why wont the device power on?
The Insignia Flex 11.6 will not power on after charging the battery and unplugging the ac adapter. However if I leave the ac adapter plugged in the device powers right on.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Put the tablet on the charger for a full 2 hours. Ensure the tablet is still connected to power and press the "Reset" button on the back of the tablet with a pin or paperclip (an ink pen likely will not reach inside the recessed hole, you will feel a button pressing when done correctly). The tablet should automatically restart, assuming it was charging prior to the reset. – Community@Insignia
このアンサーは役に立ちましたか?
I have the same tablet. Can you tell me where the reset hole is on back? I can't find it
my insignia 11.6" tablet did not have a reset button or pin hole, but what worked for me is holding down the power button for 30 sec. then releasing it and wait 2 min. then repeat the process over again. I was told to do this 3 times but it actually restarted on the second time. I was really worried as well cause it was fine last night the nothing I did would work. the person who told me to try the trick above. said that if the tablet gets hot it will shut down to protect its self. and not power back on til cooled. however my tablet was 2 days old and I'm sure it was not hot. but it still fixed it so who knows...hope this helps!
このアンサーは役に立ちましたか?
Thank you this was helpful, I pressed and hold the start button for 15 seconds just once and my tablet started again.
Thank you! I tried 3 times and my laptop turn on.
Glad it worked for you!
過去 24時間: 1
過去 7 日: 4
過去 30 日: 18
今までの合計 6,484
1件のコメント
My INSINGIA TABLET MODEL NS-P10A6100 WILL NOT POWER OFF TO REBOOT AND FACTORY RESET IT, ALL THAT APPEARS ON MY SCREEN IS "APP PERMISSION
APP PERMISSION MANAGEMENT IS CLOSED"......I NEED IT TO POWER OFF TO FACTORY RESET ANY SUGGESTIONS, THIS IS AFTER I LOANED IT TO MY MOM
Casie Brouillette さんによる
