Blaster jams and will not fire darts.
When I pull the trigger on the blaster, the darts jam inside of it and tend to bend. This simultaneously ruins the darts as well.
The gun may jam due to a faulty spring after being frequently used. It can also be that you may be using the wrong type of darts. Each spring is custom made for each nerf gun based on the darts.
このアンサーは役に立ちましたか?
Alec is wrong and right at the same time
Maybe that the gun has chewed up bullets inside the gun.
Try to check the gun and maybe screwdrive the gun apart.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 544
1件のコメント
Student question
mayer さんによる
