メインコンテンツにスキップ
Sony 40” LCD TV Model KDL-40V5100.
1回答 すべてを表示
No Image on TV Sony Bravia KDL-40V5100
https://www.flickr.com/photos/truvor/302...
Our Sony Bravia KDL-40V5100 suddenly froze, hiccuped and stopped showing an image. Instead the display started showing vertical lines that look like an aurora borealis. Sony support told me that the panel is dead. We also thought that maybe replacing the t-con can fix this, but somehow it's doubtful. Sony tech on communities.sony.com suggested resetting something on the on-screen menu. I guess he missed the part where there is no menu and no longer a screen. In other words Sony was not helpful - neither the telephone support nor the techs trawling the communty boards. (Trolling may be apropos)
Update (10/26/2016)
So I got around to opening up the panel of the KDL 40V5100 and found that there is a heat sink covering the T-Con.
Update (10/31/2016)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
22 件のコメント
Any suggestions on opening the heatsink?
さんによる
Looks like it is screwed down with some Phillips head screws. Tried to unscrew those to see what gives?
さんによる
I'll do that. However, at this point, no one has a replacement T-Con board. The Samsung LJ94-02782B is out of stock on the reliable sites.
さんによる
Take a look at the board with the heatsink removed and post some good images of it. There may be components that we can identify as the culprit. I noticed theere is at least one fuse on the T-con board
さんによる
17件以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
@truvor does not look like a failed LCD. This does look like a failed T-con board. I'd definitely start with that. Of course, open the back and check for any loose cable are well as any obvious damage as well
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thank you. I will investigate.
さんによる
コメントを追加
回答を追加する
Peter さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 17
今までの合計 1,319
