メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Cannot fully charge battery
The phone was fall down and cracked , screen was broke and battery get very fat. Screen was replaced sam as battery. Then I can't fully charge the bat , fast charging work almost perfect but only to 67% the charging was about 1pc for a 8min and stops at 70 % (still got information about fast charge). I've buy the second one battery and problem is still in my phone, so I flash the other rom, hard reset, cleaned battery connector and main board with alcohol. Everything is still same. Any suggestions?? Used only original parts.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
I solved the problem. The cause of this problem was a problem with found an original battery, i found a trusted wholesale in my country and finnaly they send me the 100% original battery.
Problem solved.
さんによる
コメントを追加
2件の回答
maybe your power charge sample resistance of phone's main board was broken!check your motherboard!
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Where to find it, got any scheme ?
さんによる
check voltage of keypiont,look for power charge chip,and replace new one,no scheme
さんによる
コメントを追加
Got the same problem...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Piotr Kaszewski さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 22
今までの合計 242
