メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
20回答 すべてを表示
My screen has a speck on it?!?
So I generally keep my MacBook in very good shape, but the other day I noticed a little speck in the middle of the display. I ran my fingers gently over it and felt something (so it's not a drop of water or something). Between the keyboard and palm rest I also found a little piece of something, which I scraped off (this is approximately the same position as the speck on the screen). I don't want to scratch at my displya trying to get something off, for fear of damaging it. Is there some way that I can:
A) Determine whether I can safely "remove" this speck, and
B) If it is an indentation or other mark on my display, can I fix it without replacing the whole display?
All help is appreciated, and thanks in advance!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Spray a little Windex on a very soft cloth and see if it will dissolve.
Update: If the speck bothers you that much, here's the guide for replacing the screen: MacBook Core 2 Duo LCD & Inverter A1181 (fast method) Replacement
このアンサーは役に立ちましたか?
スコア 3
9 件のコメント:
Thanks for the suggestion Mayer, however this did not resolve my problem (although I haven't cleaned my screen properly in a while, so it did make the screen cleaner overall). After a few minutes of rubbing at the spot, it is still there. Any other ideas? I think I remember hearing that Vaseline could be used to fill in nicks in this type of display, although I can't verify that it's a good idea or not.
さんによる
I really wouldn't put something like vaseline on my screen as it would attract dirt. Try using a magnifying glass to see what it is.
さんによる
It looks like it's a small indentation. It's darkening the pixels in about a 3x3 range, which makes it quite visible whenever I work. Any ideas?
さんによる
Look on the keyboard to what's sticking up to high and causing the indentation.
さんによる
There was a piece of something there before, I scraped it off already.
さんによる
4件以上のコメントを表示
コメントを追加
回答を追加する
Adam Hintz さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 2,161
