Why does my turn signal oonly work on one side?
Turn signal works normal on left side, but it blinks rapidly on right side and only the front light blinks.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi Dennis,
A rapidly blinking turn signal often means that the light bulb is about to burn out. Try replacing the bulbs and see if that fixes your problem. This video might help with the replacement: https://www.youtube.com/watch?v=c0Rk3kh2...
Good luck,
Paige
このアンサーは役に立ちましたか?
You need a new Turn Signal Switch, relatively cheap part
このアンサーは役に立ちましたか?
Bulb replacement solved the problem
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 121
1件のコメント
Bulb replacement worked. Thank you
Dennis Johnson さんによる
