メインコンテンツにスキップ
AT&T black corded speakerphone with a tilted LCD display and extra-large keys.
5回答 すべてを表示
landline phone ringer not working.
The landline phone instrument is working fine supporting outgoing calls but the phone isn't ringing during incoming call, the phone loudspeaker is also working fine.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Hi,
Have you checked that the ringer volume is set to an appropriate level and that the ringer hasn't been 'muted' by being switched OFF?
Here is an image to show you. (click on the image to enlarge it for better viewing)
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
I have checked that already, that is not the case,thanks anyways!
I think there is some problem in internal wiring.
さんによる
Hi,
You say that the loudspeaker works fine so this proves that the speaker (it is the same one used for the ringing signal) works. Perhaps it is the ringer switch itself that is faulty. It may have become disconnected from the board perhaps.
さんによる
yeah something like, i actually checked inside the instrument two wires are hanging out but i don't know the connections.
さんによる
Hi, What are the connections from the ringer switch like? Is the switch mounted on the pcb or wired in?
さんによる
コメントを追加
回答を追加する
Ashish Dhyani さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 11
過去 30 日: 64
今までの合計 13,768
