メインコンテンツにスキップ
16.2 Mega Pixels dual LCD smart camera. The Samsung DV180F is a WiFi capable camera with a 25mm wide-angle lens and 5x optical zoom.
3回答 すべてを表示
How do I change the brightness on the display screen?
The display screen in the back is lighting up but it is too dark to see. How can I increase the brightness of the display LCD?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The first thing you want to do is to make sure the camera is charged because one cause of the brightness being dim is having a low battery. After the camera is charged to full capacity, you want to press the main menu button which is a house button. Next, you want to go into the settings by scrolling on the top scroll bar and then you have to find the display settings where you can change the brightness higher or lower.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
John Cirello さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 35
