The handle has broken off, how do I install a new one?
The handle to my Roomba broke and I need to replace it. How do I put a new one in?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The handle replacement itself is a simple task since the handle snaps on and off(no screws required). However, accessing the handle is a different task entirely. The roomba will need to be turned upside down, and partially disassembled to reach the handle on the face of the roomba. A thorough repair guide is being created at the moment, addition information that may helpful can be found on the troubleshooting page.
このアンサーは役に立ちましたか?
where can I purchase a replacement handle?
I have seen these on eBay recently
The answer is that you need to remove the faceplate around the buttons. It's a snap-off thing and no tools are required. You need to remove the garbage container and access a press-through pin on the middle of it and carefully pull the button faceplate off with your hands.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 15
過去 30 日: 23
今までの合計 569
