メインコンテンツにスキップ
2016年3月に発売されたSamsungの機種です。モデル番号はSM-G930Vです。
425回答 すべてを表示
Bloated battery after the phone dropped
Dear friends,
Today I recieved a Samsung Glaxy s7 with a swollen/bloated battery. He said it happend after he dropped the phone. They tried to put a new battery in, but the phone still didn't powered on. Do you guys have any solutions?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
I also having problem with my Samsung Galaxy S7 Edge though. After it dropped, the battery bloated and the screen gone green eventually unusable. So I had to change the battery, the same thing it fell and bloating slowly. I'm afraid it might burst. what to do?
さんによる
コメントを追加
2件の回答
ベストアンサー
Question, statement and (hopefully) a solution:
Question: Who is "they?"
Statement: The most likely reason for bad batteries is because a small piece of foil ruptures with shock and causes the two electrodes of the battery to touch, overheat, and create problems (i.e. exploding).
Solution: Unless you're really comfortable working with at-risk lithium batteries, I wouldn't work with it, and would carefully dispose of the battery properly. If the battery bends a fraction of a millimeter too much, you could rupture that same small piece of foil and start a chemical fire or explosion. This problem was only intensified with the S7 Edge as that foil simply failed too easily. You can get a new battery from a reputable brand like iFixit and use their replacement guides. You may need to also replace the screen adhesive.
Galaxy S7 Battery
Galaxy S7 Batteryの画像
製品
Galaxy S7 Battery
$19.99
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
They = another repair guy. He said that they tried a new battery but it didn't worked. However I don't even believe they even tried to remove the battery.
さんによる
Also screen adhesive? The phone it's back is opened I will add some pictures
さんによる
コメントを追加
This is what the phone looks like atm
このアンサーは役に立ちましたか?
スコア 0
8 件のコメント:
Do you think it's too dangerous to replace the battery @skimmilk05 ?
さんによる
Can someone help me?
さんによる
Again, if you feel comfortable doing it, and think you can do it SAFELY, then it's your choice, but I can't gauge your abilities or comfort level dealing with these things. Personally, I'd go for it in a safe environment (i.e. outside with a fire extinguisher) if it were my phone, otherwise I'd go to Samsung (say if it were someone elses). I'm not too comfortable with damaged batteries.
さんによる
I tell you the whole story I know right now. He bought the phone, he dropped the phone. Someone else repaired it, battery was swolen. Went to another store, phone didn't turned one anymore/didn't charged anymore. I think it also could be the charging port
さんによる
It also went to Samsung they refused to repair it, rediculous isn't it?
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Stijn Helmonds さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 14
今までの合計 4,394
