メインコンテンツにスキップ
Lenovo's fourth generation Yoga laptop debuted in November 2015. The Yoga 700-11ISK is a hybrid tablet-laptop that features a 4-in-1 design, 8GB of ram, a 2.5 solid state drive, and an Intel® Core™ m7 Processor.
16回答 すべてを表示
Why is my computer overheating?
My computer seems to overheat when I'm using it normally. The back feels hot to the touch and all the fans are running at full speed.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
please provide more information about your computer so someone or myself can help. for example the model and type of your computer, laptop or desktop. pictures.
さんによる
Had the same problem with my Lenovo Yoga 4, bought in 2015 from Best Buy. I didn't realize it was overheating and it destroyed the mother board, making my year old Lenovo completely worthless. What a waste of money. Trashed and unrepairable due to the enormous cost to replace the board. Will NEVER buy a Lenovo again. What a piece of junk.
さんによる
コメントを追加
2件の回答
ベストアンサー
Your computer may be overheating due to a blockage in the ventilation. Make sure your computer is on a surface where none of the vents or fans are being blocked and that there is sufficient room for the laptop to ventilate properly.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
There are no fans or vent on this machine. Please dont write generic answers without even knowing what the machine has or doesnt have.
さんによる
thank you frank
さんによる
コメントを追加
最も参考になった回答
This laptop is passive cooling, see the picture... this machine with passive cooling is relative hot, when have alu or another metal body.... but when you use this laptop long time and you thin the temperature is only in last time not normal, check by CTRL+ALT+DEL the power management, maybe you have some vir and make all time cpu 100%... you also can replace the original thermal paste... when is connecting cpu and heatsink gummy, replace with Cu platte....
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Sean Wong さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 7
今までの合計 1,776
