メインコンテンツにスキップ
it says please input PUK
son was playing with phone,now its saying please input PUK
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
ベストアンサー
Hi,
Contact the Customer Care section of your mobile phone service provider, give them your phone number and once they are sure it is really you, they will give you the PUK code, which you need to enter into your phone. You will then be asked to set a new PIN code. Once you have your PUK then keep it in a safe place away from your mobile as it is the key to unblocking your SIM.
Note that if you enter a wrong PUK 10 times in a row, the SIM will be permanently blocked, and you’ll need to purchase a new SIM card.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
maybe she locked the SIM card go to your operator (SIM operator) and ask for PUK
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi, If you still have the packaging of the SIM card, then you can probably find your PUK code somewhere close to where the PIN code is. If you do not have the original packaging or the PUK code is not there, then you should go to your operator like the others advised you to.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
What if you was giv the phone bya friandsim locked up what do you do then
Update (02/22/2023)
I hate this phone ok no
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi
If the SIM card is locked you should be able to get a new network compatible SIM card (if the phone is network locked to a particular service provider) or any other network new SIM card (if the phone is network unlocked) and insert that and the phone should work. Just make sure that the new SIM card is the correct size to fit into the SIM card slot i.e. nano, micro or standard size. Check the size of the existing SIM card that is inserted now.
さんによる
コメントを追加
回答を追加する
andrew1969quinn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 19
今までの合計 3,308
