cannot turn off /frozen!
HELP my bluetooth speakers have frozen and will not turn off,even when holding on/off switch down !
thanks in ad vance
この質問は役に立ちましたか?
thanks in ad vance
この質問は役に立ちましたか?
The reset is inside the audio jack at the back. Took like an hour to put that together lol. Dont take it appart just push button and done.
このアンサーは役に立ちましたか?
Hi, your advice on the position of the reset switch at the bottom of the earphone jack socket was a master stroke, as it’s a bit longer than an Apple key, I used a paper clip, felt it click and switched the speaker off, switched the speaker on normally all works fine. Thank you.
@alanlroberts yours was the very best! and it worked. The worst of it was the speaker is my dads and he has warned i should stop tampering with his stuff. Imagine my worry when his speaker froze.
Thank you very much. And guys in @alanlroberts advice,if you don't have a paper clip,you can use two pair of sewing needles
So helpful. I was push all the small holes on the top of the speaker but nothinh happen. No one tell details like yours. Never imagine the hole reset is on the audio jack. I was reading somewhere it can be the hole of mic indicator etc. So many holes but even in the manual they do not mention exactly the reset button itself. Thanks to you.
wooohoooo i fixed my speaker by the reset button thats located in the bottom of the aux port thanks to the above comments i now have my speaker back after days of confusion .
thanks
Who the !&&* posted this ansaer,? How in earth did you even get there??
Well this was very useful, you've saved me from the earth if my mom
It happened to me yesterday. My bluetooth speaker was frozen. So I let it for 10 hours until all its battery go down and then it turned off. After that I turn it on.
このアンサーは役に立ちましたか?
It happened to me today?.my bt speaker was frozen .
Worked for me on my Antimi Bluetooth speaker! I cut the pointy end off a round toothpick and used that to reset via the headphone jack. It was quite easy. Letting it drain the battery down completely works, too, but takes too long.
このアンサーは役に立ちましたか?
How did you Discover this.
It worked for me thanks
Worked for me on my Antimi, as well. The part about cutting off the pointy end is important, it won't work if you keep the point on the toothpick. Thanks for this tip, Tony!
8 Years later and still your solution worked for me- Thanks! I have an older small Escape Bluetooth speaker. The sound is great and recently froze in the "on" mode. Literally 2 secs after using your fix, it is as good as new.
このアンサーは役に立ちましたか?
I actually discovered this on my altec lansing life jacket one night working grave yards at local convience store lol. Love seeing that 8 years later can still help ppl out. Maybe I should post some more answers on here lol.
amazing! my konzert speaker from loacl philippines market was fixed. i used a toothpick to find the reset button in the microphone slot and in works like new!! thanks!
このアンサーは役に立ちましたか?
I have other ports on my speaker but not headphone. I GT, Mic and Aux. Which one should I use.
過去 24時間: 4
過去 7 日: 36
過去 30 日: 222
今までの合計 88,366
7 件のコメント
You can try this, it worked for me. I just let me battery run all the way down. Recharge and that has seemingly fixed the problem.
drunken_stumbles さんによる
Does anyone know how to reset a Gooodmans waterproof speak mine won’t turn off
Morgan loves bts さんによる
Please I really need your help.... Was playing my UE roll 2 speaker ,its went off immediately I plucked the charger.. For the past 1week its not turning on or charging
Madison Adams さんによる
The last time something like this occurred... Its started charging and turned on after a month or more than without any repair... Thanks in advance
Madison Adams さんによる
My BS-218 was playing very nicely when it said my battery was getting low. I charged it and was attempting to play it again. When I powered it up, it said in slow motion, Bluetooth mode. Thats all I can get is slow motion response. Pls help.
David Reynolds さんによる
2件以上のコメントを表示
