メインコンテンツにスキップ
Repair guides and support for smaller headsets that rest on top of the ear, also known as supra-aural headphones.
60回答 すべてを表示
Can I solder broken wire back on using the old solder blob?
Hi! My headphones broke on one side. I can see the broken wire inside the ear cup and was wondering if I could just melt the solder that's there and push the wire back in. (after snipping the wire). I've never soldered before and don't know much about electronics.
Here's a picture, you can see where the wire's all broken.
https://postimg.org/image/6fcajabhl/
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
Christian, as Shelton stated could be possible, but if you want a good clean trouble free repair at least get a little flux/rosin cored solder so you will have a clean soldered connection, saves from having to do it twice.
A small amount of rosin core solder can be purchased at most electronics stores and big box stores as well.
Below I will post a tutorial on soldering. Good luck.
https://www.youtube.com/watch?v=Qps9woUG...
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Should be possible, your picture isn't the clearest though. Before of your temp when soldering you don't want to melt anything. Maybe watch a few basic videos on youtube before you try.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Christian さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 30
今までの合計 2,943
