メインコンテンツにスキップ
The sedan version of the compact Toyota known as the Echo, Yaris, or Platz depending on the market. The hatchback version of the Echo/Yaris is known as the Toyota Vitz.
11回答 すべてを表示
What type of 02 sensor do I need?
2003 echo
I need to replace my 02 sensor, the mechanic took mine out and said I needed to go buy a new sensor. I was told that there are 2 different types of 02 sensors, a 3 wire and a 4 wire sensor.
4 cylinder, 5 speed, 4 door, automatic.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
Your local parts store should know. Your mechanic took it out, what did he do with it? He knows which one it is. Ask for your part back or look.
Here's the four wire: http://www.carparts.com/details/Toyota/E...
Here's the three wire: http://www.carparts.com/details/Toyota/E...
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
mayer, question for you, who decides chosen solution to an answer and why would some one choose some ones question as the chosen solution/accepted answer when I was the only one that posted an answer. I have noticed this a few times. example of what I am mentioning in link below. Thanks for your response in advance.
Starter relay location under dash
さんによる
@lpfaff1 On this one Dawn, the OP, posted her own answer (that was actually a comment). The OP of a question can accept any answer. Looks like she likes herself more than you ;-) I have left her a comment on this.
You can vote on any question and also vote via moderation to vote up an answer for acceptance or several other options. We get so little voting that this seldom happens (just lack of participation).
Moderators can accept or kick a question off with just our vote,
さんによる
コメントを追加
The continuing advancement in technology has brought many changes to the structure of today's automobiles. While vehicles of yesteryears were equipped with extremely large and unrefined engines, new vehicles are equipped with smaller engines that produces more power at a refinement level way above the engines of the past. BUY OEM PARTS FOR CHEAP
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joe Thibault さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 173
