メインコンテンツにスキップ
モデル番号 A1051 / 4 もしくは6 GB ハードドライブ
90回答 すべてを表示
締切られた回答
After replacing my Logic Board why does my Display not function?
Okay I'm looking for some help fixing my 1st Generation iPod Mini, I got it broken from a friend and when I first got it I plugged it into iTunes and got no response at all. I then brought a replacement battery from iFixit and installed that at which point the iPod did boot, I can only assume from some residual power left in the battery, and displayed the sad iPod icon and wouldn't go any further. I then took this to mean that the logic board was gone so I ordered and replaced the logic board but after I had put in the board and was connecting the display cable back to its relevant connector I noticed the connector on the new board was bigger than the old one but I simply reconnected the cable anyway and continued. Now when I connect the iPod to power I don't get any kind of screen response but I can hear the hard disk heads moving so there must be power in the board. I've begun to think that the display connector is the problem but does anyone have any insight with which they might be able to help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
You may have ordered a logicboard for a 2nd generation mini, which has a different LCD and connector. You'll have to now find an LCD for a 2nd gen mini, or find another 1st gen mini logicboard.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 6
今までの合計 1,185
