メインコンテンツにスキップ
2014年9月に発売されたSony Xperia Z3 Compactの修理ガイドです。
82回答 すべてを表示
Original screen adhesive, how to use?
Hello, I got this screen adhesive
witch I believe needs to be heated to stick to LCD and frame, but I already tried to do like 4 phones and it doesnt hold. Im trying to heat it on 85-90C for about a minute, do I need more heat or hold it on there for longer?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
I use heatgun, but carefully. I have a heatgun (HG) with small nossle. First clean the edges of frame with isoproponol, then put the adhessive sheet with the glue side down. Use the HG to warm carefully the corners and use a tip of a tweezers to press so the adhesive stick. You can see it when it stick to the fram, it become more transperent. Then do the rest of it.
Then take of the plastic "cover", install the screen and do the same heating on the screen it self. On the sides, make surre you heat only the 1 mm edge. I use my fingers with a paper or something to press and swipe the heated area to make sure the screen is pressed down until adhesive is holding it.
Heat plate can also be used. There are many othe similar questions in the forum descriving the same.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi, this blog tell you the differences between original screen adhesives and non original ones, also tells the way of how to use the original screen adhesive, maybe you can have a check http://www.etradesupply.com/blog/what-yo...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Eimantas さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 703
