メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年8月に発売されたLenovo Y50-70 Touchは、LenovoのYシリーズノートパソコンの1つです。専用のグラフィックカードと15.6インチのタッチスクリーンを搭載しており、ゲームに特化したモデルです。
How do I replace my keyboard?
Most of my keys do not work and sometimes they do. It has been an on and off problem for a while now. Is there a way to just replace the keyboard and if so does anyone know where there is a guide to do it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
ikameshia you can download the service manual for your computer from here The keyboard is considered part of the upper case. Here are some decent instructions on how to remove it :
"The first step to replacing your laptop keyboard is to remove the screws from the back of your Lenovo Ideapad Y50-70. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your Y50-70 laptop manual for details.
Above your Lenovo Y50-70 laptop keyboard, you have a cover panel. If required, remove this part to easily access your Lenovo keyboard.
If you have screws above your Lenovo Ideapad Y50-70 Keyboard, remove those screws.
Now that you have removed all the screws, you are ready to remove and then replace your new Lenovo Y50-70 laptop keyboard.
To remove your Y50-70 Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing your Lenovo Ideapad Y50-70 Keyboard.
Now that your keyboard is loose, simply disconnect your Lenovo Y50-70 keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your Lenovo Y50-70 connector cable should be easy to remove by simply sliding it out.
Now that your Y50-70 keyboard has been removed, get ready to install your new Lenovo Y50-70 laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of your Lenovo Ideapad Y50-70 laptop." from here.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
This is missing some crucial info. How do you take the keyboard out. It's mounted to a metal panel with plastic rivets and cannot seem to take the keyboard out to replace it...
さんによる 共有
Yes I agree, all the techs at best buy keep telling me "slide something between and pop it out" but all the laptops I've tried this with had plastic rivets...
さんによる 共有
@matthew2overby3
This link may answer your question. usually you have to cut/melt the rivets and then glue to keyboard back on.
Different brand but the principle is the same.
Keyboard replacement possible? Dell Inspiron 3147
さんによる 共有
Please send me video
さんによる 共有
コメントを追加
回答を追加する
ikameshia さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 35
今までの合計 8,994
