メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Repair guides and support for your Sanyo TV.
TV keeps shutting off
I have a 2010 46 inch Sanyo LCD TV, model number DP46849 that shuts off just a couple seconds after I turn it on and will not let me turn it back on for about 20 more seconds then stays on for 2 seconds and back of again, this is all it will do, should I junk it or can I fix it or would it be best to leave it to the pros
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
5 件のコメント
glseese sounds to me like you are having component(s) that get to hot and shut the power supply down. Remove the back of your set and take a look at the power board for obvious issues like leaking or domed looking caps. Post some images of what you see with your question so we can check it out as well. For that use this guide iFixitでの質問に画像を追加する方法
さんによる
Is there no easier way ? Sure I can unscrew the entire back of the TV. But I would not know what I was looking at or where to look or what to do. I am no electrician. When I buy something like a TV, a relatively expensive and complicated item, I should not be expected to play electrician when something goes wrong. I am so fed up with this attitude towards providing customer : listen to a bunch of words that ean nothing to me and be told to run a.one and try it myself. Please ! I have a Sanyo HD LED 43” TV now, but from what have seen, this can happen on any TV.
さんによる
@Patricia Holub
This is a forum to help people fix their devices themselves. This forum doesn't represent manufacturers. It is just people trying to help people fix things themselves.
If you are having problems with your TV and you cannot understand what has to be done to check it yourself to hopefully fix it, then contact a reputable, professional TV repair service and ask for a quote.
If the TV is still covered by the manufacturer's warranty, then use that to get it fixed.
Moderator
さんによる
My Santo tv keeps shutting off when I plug in DVD jacks
さんによる
@chuckhowell
What is the model number of the TV?
What do you mean by dvd jacks - HDMI socket, Component video RCA sockets (red/blue/green video + red white audio cable), Composite video RCA socket (yellow video + red & white audio cable) as all of these can be used to connect a dvd player?
さんによる
コメントを追加
2件の回答
最も参考になった回答
I recently had this issue and was able to find the same tv with a damaged screen that I could use for parts. After swapping the power boards. I still experienced the same issue. I then unplugged the board that controls the power button on the side of the tv and the problem went away. I then swapped the boards from the spare tv and all is working fine.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I will try the control board. I have 2 of these TVs and both do the same thing. And the power supply seems to be fine
さんによる
コメントを追加
glseese once you removed the back and have taken your pictures to post with your question, check the TV according to the flowchart.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
glseese さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 55
今までの合計 7,887
