Why will my tablet not turn on?
Screen has gone blank, will not turn on. I have not tried anything because I don't know what to try. There seems to be no power source. Could it be the battery?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Lynne, You may have ran battery down too low and cannot take a charge from Asus a/c wall charger and will not power up. Try this, 8 hour trickle charge your tablet from a low voltage/amperage connection, plug to PC USB port to the charging connector on your tablet, or use a low power phone charger 5 volt/500 ma. From forums I have read, lithium batteries do not like to be drained fully. Good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 689
