メインコンテンツにスキップ
This is the non-touchscreen version.
9回答 すべてを表示
How to I factory reset my managed chromebook
Hello, I purchased a chrome book off of craigslist. I found that it was a managed device ive tried several ways of rebooting , power wash, esc, refresh, power even reinstalling the operating system, but didn't get any accurate results. Is there a way I can go inside the chromebook and reset it from there? It's kinda useless as a home laptop if I can't do anything on it. The model is a Dell chromebook 11
Any tricks to return it to factory ??
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
3 件のコメント
Have you tried asking the Craigslist seller?
さんによる
Yeah, unfortunately he hasn't responded to anything i've sent and I reported him to the community. If i can't get a hard reset to work on the computer then i'll just buy a new one from Best Buy
さんによる
sign in press ctrl+alt+t it will open crosh then type rollback and see if that helps
さんによる
コメントを追加
3件の回答
ベストアンサー
Depending on the newness of the model removing the program screw will not remove the management. It’s up the to the business or place thats managing the device to release the management. You can perform a simple powerwash which is ESC+REFRESH+POWER then CTRL+D then space bar and enter. This will wash the device but depending on the managment you may need credentials from the original manager to enroll the device.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
you turn off your chromebook and press ctrl+esc+refresh+power button than ctrl+d than enter than ctrl+d
then you have to take out the write protect screw near the HDMI port you have to open the chrome book though
it will reboot factory reset.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I purchased a chrome book 3100 and unfortunately it’s managed I suppose, I took the back off to replace the hard drive and I can’t find it.. Am I just over looking it? Does it not have a hard drive because it’s managed?
さんによる
@slackr420 The SSD is soldered to the motherboard.
さんによる
コメントを追加
get a new enternal hard drive or have a pro wipe it free of eney thing i have the same prob but it is at my other home if you check out realgatis plays maby soon i will upload a vid about fixing that
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Elliot smith さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 49
過去 30 日: 163
今までの合計 13,774
