メインコンテンツにスキップ
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1525回答 すべてを表示
Weird screen issue - anyone seen this before?
So about 2 months after I replaced the iPhone 6 plus LCD this happened!
http://oi66.tinypic.com/5v92j5.jpg
It is static. The touch seems to respond as I can blindly hold the power button and slide to turn off but the image doesn't change!
Anyone encountered this before please help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント:
BTW I tried reconnecting the flex cables, looked for any signs of damage but found none.
さんによる
Did you disconnect the battery connector and reconnect, then do a hard reset?
さんによる
Yeah sometimes it's the screen or a nand flash memory issue (not enough space / overfilled / corrupted / damaged).
さんによる
The problem is that when I connect another screen then the phone works fine.
And when i connect this bad screen to another phone it has the same issue.
So the issue must be with this screen...
さんによる
コメントを追加
1 件の回答
I actually saw this for the first time today on a 6+, may not be the same issue though as this one would be fine but freak out periodically go all staticy then screen would go blank, I worked out that somehow the phone had overfilled the memory by 2.5Gb (don't ask me how or why that was just what iTunes told me) and I noticed that it had downloaded the latest update so I installed it (freed up about 3Gb) and it seemed to come right, hasn't freaked out yet (after about 3 hours of testing)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jackchangpoker さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 104
