メインコンテンツにスキップ
モデル番号A1502 / 2.4, 2.6, 2.8 GHz デュアルコアIntelプロセッサ/ 2013年10月発売
552回答 すべてを表示
No SSD found in recovery mode after liquid spill and clean up
HI
Recently i cleaned my macbook with isopropyl alcohol because i spilled ice tea on it and when i tried to start my macbook again it showed me a flashing folder with a question mark.
After cleaning everything, I keep getting the flashing folder, so i tried the recovery mode, but when i tried to reinstall the OS on my mac he couldn't find my SSD.
I tried a lot to fix it but still nothing... anyone who can help me with this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Try the SSD in another 2013+ MacBook Air/Retina to eliminate this being the cause. Check the SSD connector for burnt pins. Beyond this, you will need a board view, schematic and soldering skills.
In schematic, find the section about the SSD connector and check the board around the supervisor clkreq circuit for anything burnt. There are also a group of small resistors on the back of the board, on the side opposite the ports, which can easily be damaged by liquid, some responsible for SSD signals.
If it is the board, usually it is a nightmare, have a 2015 one myself I need to get to the bottom of. Make sure the SSD works first, then check out the board afterwards.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Jup that's what I did, and i ended up paying 50€ for a second handed ssd, which is no money compared to what apple services would ask for a repair, thanks for answering!
さんによる
コメントを追加
回答を追加する
baptistetahon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 946
