メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Want to help me troubleshoot TouchID? I'm in Dallas.
Hi friends,
I'm having trouble with the TouchID on an iPhone 6. I did a screen replacement. Very careful to use a little heat to remove the home button cable. I don't believe it's damaged. BTW, this is a personal phone of mine. Luckily not belonging to a customer.
Factory reset, reset network settings, reset all settings. None fix the problem. I've tried disconnecting the battery and reconnecting.
I'm hoping someone will help me take a look at this. Maybe a bit of mentorship. I pay in beer if that makes any difference. I come to you?
I'm in Dallas.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント
Any signs of damage on the home button extension cable? This part is attached to the large metal plate shield that sits behind on the black part of screen.
さんによる
I move the metal plate from the old display to the new display with the home button extension cable intact. I don't believe there was any damage. Maybe its worth trying to replace?
さんによる
Worth a try, the top side of the home button extension cable can be cut / damaged / punctured easily by glass when the glass is cracked a lot or missing from the top.
さんによる
I've ordered a replacement home button extension cable. Maybe that will do the trick.
I'm slowly getting my feet wet in the repair business. Taking my licks as a I learn the finer points.
I was hoping to use this phone to demo software as a Sales Engineer in my day job. Without TouchID, I can't use this iPhone for that purpose.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Replacing the home button flex cable fixed the issue, I believe. I also restored the phone using iTunes. TouchID works now!!! I'm not a butter fingers wrecking ball when it comes to delicate electronics... woohoo!
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Does Dallas Beer Kitchen around lower Greenville make a good stout?
さんによる
Mayer, there are usually six or so to choose from on tap rotation. Tasty, too! You in the area?
さんによる
コメントを追加
回答を追加する
James Miller さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 87
