a sheet, probably wrapped around
My washer is a stacked unit w dryER on top. The problem I have is it doesn't have the agitator.....it's a sheet, probably wrapped around the new style washer's middle thingy. Please help! Thanks!
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Jennifer, You may have to remove the impeller/wash plate to get the sheet untangled from beneath it.
Below I will post a video, may not be your exact model but will show how a impeller is removed. In the future it is best to include all the info. you can make, model #,etc. as oldturkey suggest in order for ifixit to give best solution. Check the attached vid. link, Good luck.
このアンサーは役に立ちましたか?
How to remove a stuck Kenmore 500 Series Impeller?
過去 24時間: 1
過去 7 日: 7
過去 30 日: 12
今までの合計 1,428
1件のコメント
Jennifer Rose, what make and model is your washer?
oldturkey03 さんによる
