メインコンテンツにスキップ
2012年3月16日に発売されたiPad Wi-Fi機能搭載の第3世代モデルです。モデル番号はA1416です。修理には温めて、慎重にこじ開ける作業が必須です。
got restore error (21) showing up NEED HELP ASAP
i was playing 8 ball pool and suddenly my ipad 3 died, i put it to charge and after 15-20 mins i see it shows 'connect to itunes logo' the usb sticking upto itunes kinda thing, then i connect it to itunes downloaded the firmware as it shows it needs to be restored, cant be updated, so after that i still try and fiddle with it but no success my ipad is still unconsious. need help.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
First you have to plug the "iPad " to the computer and open the " iTunes".
Now put your iPad device into "DFU" mode so that you will restore the device .
For putting the device into DFU mode by just follow the steps:
Turn "OFF" your "iPad" and "HOLD" down power button for 3 sec.
After enter into "DFU" mode your "iPad" screen goes blank and get pop up message in iTunes apps “Device in Recovery Mode".
After all these your iPad device will start to restore back to the i OS firmware.
This process will take latest 10 minute for processing so never disturb or do any thing with device.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
What says Mayer is correct as the first thing to do. You must connect your device to Itune via your computer and force the DFU mode instead of being in restore mode. In DFU, your screen remains black (no Itune Logo as in restore mode).
Then you will enter in recovery mode and you will let Itune doing its job .
But if it doesn't work, and reading your history, I wouldn't be surprised if it doesn't work, it could mean that a component has passed away in your device. :(
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
raghav7738 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 5,844
