Why don't my headphones work?
When I plug my headphones into the headphone jack no sound comes out of the headphones.
Did you install the audio driver? If so, reinstall it. You can also check out our troubleshooting page for more info. HP Pavilion dv6-6180us Troubleshooting
このアンサーは役に立ちましたか?
Hi,
If you usually use the headphones to enjoy music and songs while doing work on the personal computer then you don't actually need wi-fi headphones. The wired ones definitely will do the job if you need to connect them to your own smart phone or tablet. In most cases wired headphones will be a cheaper selection in comparison to the wireless headphones.
For those physically active throughout the day wireless headphones will be a better option. The very bad thing in relation to wireless headphones is they may encounter interference from different wi-fi products around But it's good to know that Bluetooth headphones are safe from that.
If you're a bit suspicious regarding the quality of sound among those two types of headphones, you've got nothing to worry about.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 120
