Will not switch to impact mode
The drill will not switch to impact when drilling
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Steve, If your drill is indeed switchable and not just a impact driver, if the hammer mode switch feels sloppy or to easy to switch, the switch has came out of position or broken a tab inside drill. If switch seems normal but you are not getting hammer mode the wing disc and gear could be seized, worn or broke. I will post a link, not your model but should be similar to show how the hammer function works and the common components. Good luck.
このアンサーは役に立ちましたか?
If Steve is, in fact, referring to a Ridgid R86034, it is not switchable, it's just an impact driver. FYI for all
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 445
