メインコンテンツにスキップ
Repair guides and support for the 3rd generation Ranger, a compact pickup truck manufactured by Ford.
72回答 すべてを表示
Why is my battery slowly draining?
The battery and alternator have been checked out and are good. I can drive the truck all day and it stays charged, but I must disconnect the battery cable when I park it overnight or it will be dead in the morning. I have checked wiring on all the harnesses and they look good. Where do I look next? Is this a common problem with Fords?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
選択されたソリューション
Penny, If battery is indeed good, you are experiencing what is known as a parasitic drain of battery. Parasitic drain means something is using power when it should not be, could be a aftermarket alarm/stereo, stuck relay, shorted wire/switch, faulty alternator, etc. I will post a link to show how you can check your vehicle for parasitic draw by pulling fuses and checking amp draw/power with a DVOM. Good luck.
https://www.youtube.com/watch?v=zdIKNnwE...
このアンサーは役に立ちましたか?
スコア 7
2 件のコメント:
Some short circuited then some current all time flowing that's battery drain
さんによる
@lpfaff1 Excellent choice for a teaching video , really like using ETCG stuff for simple explanations
さんによる
コメントを追加
If alternator is and batter are good checks the starter and starter solenoid they can draw power (parasitic draw )
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Penny Peterson さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 56
過去 30 日: 236
今までの合計 15,463
