メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
iPhone 5 Battery Replacement Question
Hey guys,
So I want to do a mobile iPhone 5 battery replacement, but I don't want to disconnect the screen.
My question is: If I replace the battery of an iPhone 5 without disconnecting the screen will it later cause any problems?
Is it safe to do when I keep it in that 90° position?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You can do it without removing the screen, and it won't cause any problems, a long as you can keep it supported at 90 degrees. If it overextended or twists to the side it could be damaged. The 5 has a very short flex cable on the LCD.
Personally, I remove the screen, as it makes it much easier to get a good angle to remove the battery and don't have to worry about damaging the screen.
Is there a reason you don't want to remove it first?
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Yeah, I repair the phone at college but as you say, you're right. I should disconnect the screen. However I could use my drotterpod, it keeps the screen in place very strong. Can I use that without disconnecting the screen?
さんによる
If you are doing this for money, you owe it to your customers to do it the right way. You are going to put undue stress on the cables and connectors. Why on earth wouldn't you take the extra 30 seconds to take the screen off?
さんによる
True, I will take the screen of . I was just like: maybe I screw a connector when re-connecting the cables from the display.
さんによる
コメントを追加
回答を追加する
Stijn Helmonds さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 66
