iPhone 3GS, ringer mute button flakey
iPhone 3GS ringer mute button is flakey.
Sometimes when shows it is off, it is realy on.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
It's a tiny plastic switch on the cable, it may have dislodged from the groove on outer switch. Try sticking oout outerwitch in mute position with some tape while re aligning plastic switch(in down position) into groove. It's quite fiddly and takes patience.
このアンサーは役に立ちましたか?
dismantle it and find out if it is connected properly?
look for the 6 and follow the cable upwards, unscrew that.
then there is a screw on the side that holds it in place.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,639
