メインコンテンツにスキップ
Repair guides and troubleshooting for the 40in LCD TV with model number LA40R81BD or LA40R81BDX. This television was released in early 2007.
46回答 すべてを表示
Is it the backlight converter?
Hello, samsung 40" tv stopped working. When turning on there was some pixelated light on the screen but then it went straight into standby. Looking at some online advice I thought it might be the backlight converter.....then somewhere else is said it might be the power source to the backlight converter.... Any ideas appreciated as to anything else it might be, before I go for the converter?
many thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@flashman what is your definition of pixelated light? If you darken the room and shine a flashlight at an angle agianst your LCD screen can you make out anything on the screen (Your TV has to be on and at a channel that normally display something;-) Open up the back and check the cables and individual boards for anything obvious like domed or leaking caps.
Just checked the Samsung Service Bulletins and your model shows up as potential SMPS failure due to SamHwa Cap causing MAIN BOARD EEPROM setting change. So you do need to check the boards. The caps in question are as follows
CM852,CM853,CM876,CM880,CB850,CS806,CM811,CM812,CM817,CM808
If unsure post some good pictures of the boards with your question. For that use this guide
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Anthony W さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 104
