Why is my machine not washing/rinsing well?
I am having trouble with the machine not progressing into the rinse cycle. I do get a code for not draining, but the pump works fine and is not clogged. The machine does take a while for it to respond to inputs. I changed the circuit board but the problems still exist. The users use a large amount of laundry soap I found out so I ran the machine without soap for an extended amount of time to rinse any residue away. I have not gotten a code for SUDS either.
After taking it apart for the fifth time the machine ran well throughout the washing cycle but once again stopped prior to rinsing with a no drain code. Any ideas? thanks
1件のコメント
@cleanguy which code did you get
oldturkey03 さんによる
