Can I replace the screen on my Asus Chromebook C100P?
Can I replace the screen on my Asus Chromebook C100P? It is cracked and needs a new one.
I have the same problem. Couldn't find the replacement screen, could you?
このアンサーは役に立ちましたか?
Yes, I did. Very expensive. $177... AGParts Worldwide 220 Huff Avenue, Suite 400 Greensburg PA 15601 (724) 838-9588. This is the part number: 90NL0971-R20010 I spoke with Julie Ulery. When you order this make sure you specify the screen only or the entire casing. Not sure if they sell the screen by itself. Let me know if you need aditional help!
過去 24時間: 2
過去 7 日: 2
過去 30 日: 10
今までの合計 4,374
