To reset the unit to factory setting:
1. Power on the unit by pressing the on/off button for about one second.
2. Press the "Vol - " button and the "Bluetooth" button together for more than 7
seconds.
3. The unit will display Red, Green, Blue light and go into power off stage, but with the
on/off light and the light symbol lighted up.
4. The unit is now reset to factory settings.
5. Switch the Pulse OFF by pressing the on/off button for about one second.
6. You can now turn your device back on and it will be reset to factory settings.
5 件のコメント
Hi.. i have JBL onbeat awake bluetooth speaker.
It is shown UP 9 on display .
How to fix it ?
Hemant さんによる
Hi Hemant, did you fixed? I have the same problem.
Sara さんによる
if you use JBL Pulse 2, Press + and Play buttons instade of - and bluetooth buttons.
Zo YoungIck さんによる
My issue - Pulse 4 lights were on.
Solution - Press Volume + Power button until device switches off
This worked for me
Shefali Agrawal さんによる
In case useful... I have a pulse 3 (white) which to reset was + and Play buttons (nice share Shefali). Also, it's April 2022... do NOT update the speaker firmware if you have a mac M1 chip... it probably will fail to play (but will connect). I've spent about half a day trying to get it to work - resetting speaker is the only option I could find. Cheers all!
Adrian Watkins さんによる
