Why is my battery draining quickly?
My device is draining really fast, I haven't been able to keep it on for more than a couple of hours without having to connect it to the charger.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If the device will power on, terminate all running applications and launch the device into airplane mode. This will allow for 100% of power to go towards basic function. If the device continues to burn through battery power at a high rate, the battery may require replacement. If the device will not power on, check to make sure battery has no warped edges or bulging.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 18
今までの合計 1,938
