メインコンテンツにスキップ
2016年3月に発売された4インチのiPhone。ハードウェア仕様は6sに類似しています。シルバー、スペースグレイ、ゴールド、ローズゴールドのカラーが揃っています。16/64 GB容量、Model A1662とA1723
1049回答 すべてを表示
Why is my wifi and Bluetooth signal weak after changing my housing?
I purchased a new iPhone se housing from eBay because mine was damaged. However my wifi only works when directly next to the router. Same with Bluetooth, it has a lot of static and is only clear when I hold my phone directly next to my Bluetooth headphones. I have tried two different wifi antennas now (a new one and the original) and it still doesn't work like before. Please help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
5 件のコメント:
How much did you pay for the housing? Is it an original part? Does it have all the correct model numbers etc on it?
There are a lot of cheap knock off phone parts on the market.
さんによる
Pretty cheap, also shipped directly from china. I was unaware that the housing would interfere with the wifi antenna. Do you think the housing is the issue?
さんによる
Almost definitely.
さんによる
So I have put everything back into my old iPhone se housing to see if it really was the housing and the problem persists. Any ideas as to why? It's definitely not the wifi flex cable, I have tried multiple ones. Any suggestions are greatly appreciated.
さんによる
After disassembly and straightening of bended iphone SE I have poor GPS and Bluetooh. I replaced the housing (cheap compatible) with hope that it will help. However, it has not helped.
I have already discovered that I have lost small bracket beneath left-top screw of the logic board. I tried to use just small metal washer - it has not helped. I have disassembled the phone already several times! Please help.
さんによる
コメントを追加
1 件の回答
Maybe the housing is defective or is poor quality and the antennas in the back of the phone and not reaching the towers.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I pitched this housing directly from china as the price tag was very low. I guess you get what you pay for. But I didn't think the housing quality would affect the antenna but I could be wrong. To my knowledge only the iPhone 6 has the antenna on the housing is this correct?
さんによる
コメントを追加
回答を追加する
Jeremy さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 268
