メインコンテンツにスキップ
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459回答 すべてを表示
Flashing Samsung galaxy s 3
I have samsung galaxy s3. WHen i charge it gets charge easilly but when i connect to pc it doesnot recognized. I tried lot of other ways but none of methods worked for me. My friend said that software changing can fix this problem. Now i am confused that if mtp mode doesnt shows on pc but chrages then can i flash. And if not then what method i use.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The Galaxy S3 is basically famous for having charging port issues. It sounds like the power and ground connections are fine but the ones that handle data are not making connection.
A charging port change is what is needed. If you have soldering skills, its not that hard of a job. Or any reputable repair shop will make short work of this for you.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
its ok but my wifi range has also been suddenly reduced
さんによる
コメントを追加
回答を追加する
Naseeb さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 50
