メインコンテンツにスキップ
Released in December 2011, identified by model number LT2016U. Repair requires screwdrivers and pry tools. Black / 10.1" Display / 1.6 GHz Intel Atom Processor
4回答 すべてを表示
netbook FAN smells like DETERGENT
Hi there can I ask i just brought a 3g motherboard of gateway LT2016U at Ebay and i just wonder if this motherboard has a problem, just notice its smells like a detergent. on his cooler fan.
no problem with performance it runs smooths and stable fast. and operates in normal temp...
is this something wrong with this?
please help me thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I personally don't like the sound of a motherboard that smells like it's been cleaned with chemicals. It may however, just have sat for a long time in someone's home who uses a strong laundry detergent that lingers in the air. It would make sense that the dust particles in the fan particularly have a strong scent.
The only thing I would use on electronics is denatured alcohol, which evaporates quickly and shouldn't leave a smell. If the smell is more like an abrasive chemical cleaner and strong across the entire board, I personally would return it. Even small amounts of liquid can cause corrosion that manifests problems later down the road.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks for that info Patrick i am agree what you have said . well i will chat the seller of this motherboard.. so i can ask for refund. the reasons why i brought this because i want a built in 3G on my netbook and its hard to find a 3g motherboard here on ebay at cheap price.. well i will observe this and try to use it continuously to test if will cause a problem soon.
さんによる
コメントを追加
回答を追加する
Nic Norman Tugaff さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 87
